  • Andrew 142 posts 98 karma points
    Jan 18, 2010 @ 14:43
    Andrew
    undefined
    Hi All
    First off, this is my first time using contour and I am well impressed. Well done on an excellent product. I think from now on all my clients will need to get this by default!
    Anyway - onto my question at hand. I have looked at the sample xslt for displaying comments, but am wanting to modify it slightly to suit my needs. What I am wanting to do is the following:
    1. get comments from current page and all pages underneath
    2. display x random comments (where x is a macro defined value)
    I think i could possibly work out how to get the x random part right, but am not sure about point 1. Any help would be greatly appreciated
    thanks in advance
    Andrew
    Here is the original xslt:
    <xsl:template match="/">
    <!-- To use this sample out of the box, you'll have to have a form on the page that has a 'Name' and a 'Comment' field -->
    <!-- Get all approved records of the current page by using the library method GetApprovedRecordsFromPage -->
    <xsl:variable name="records" select="umbraco.contour:GetApprovedRecordsFromPage($currentPage/@id)" />
    <!-- Display the number of records -->
    <div id="recordscount" style="padding-bottom:10px">
    <xsl:choose>
    <xsl:when test="count($records//uformrecord) = 0">
    No comments
    </xsl:when>
    <xsl:when test="count($records//uformrecord) = 1"> 1 comment
    </xsl:when>
    <xsl:otherwise>
    <xsl:value-of select="count($records//uformrecord)"/> comments
    </xsl:otherwise>
    </xsl:choose>
    <div id="records">
    <!-- Loop all records -->
    <xsl:for-each select="$records//uformrecord">
    <div class="record" style="padding-bottom:10px">
    <!-- Display 'Name' field of the record, make sure there is a field called 'Name' on the form -->
    <cite><xsl:value-of select=".//fields/name//value"/> </cite> Says: <br />
    <!-- Display the creation time and format it using the umbraco.library method LongDate, each record has a created node that contains the creation datetimestamp -->
    <small><xsl:value-of select="umbraco.library:LongDate(./created)"/> </small>
    <div>
    <!-- Display 'Comment' field of the record, make sure there is a field called 'Comment' on the form -->
    <xsl:value-of select="umbraco.library:ReplaceLineBreaks(.//fields/comment//value)" disable-output-escaping="yes"/>
    </xsl:for-each>
    </xsl:template>
    Jan 18, 2010 @ 14:48
    Andrew
    I do not know why the title says undefined - but it should say "Contour - XSLT List comments" - Admin?
    Jan 19, 2010 @ 15:04
    Andrew
    solved
