Where is the GUID in the new Umbraco Forms? I Can't seem to find it anywhere!
Also there doesn't seem to be an insert form macro avaiable in the RTE anymore?
Thanks,Amir
Alright, I see now that the GUID is in the URL of the form, but still totally lost on how to insert the new forms into an RTE / Grid.
So, looks like the insert form macro is not enabled for use in grid / RTE by default, also a few more installation steps than with Contour: http://umbraco.tv/videos/umbraco-v7/implementor/extending/umbraco-forms/installation/
-Amir
Hi Amir,
Did you see this video about how to add a form to the rich text editor http://umbraco.tv/videos/umbraco-v7/implementor/extending/umbraco-forms/adding-forms-to-your-content/
You also need to check that the Use in rich text editor and the grid option is chcked for the insert form macro and Render Forms Scripts macro like the screenshot below.
Hope this helps,
/Dennis
Hi Dennis, yep, figured it out.
I was expecting it to be plug and play like Contour, but a couple of easy steps were required.
Upload image
Where is the GUID / Insert Form Macro?
Amir
-Amir
Hi Amir,
Hope this helps,
/Dennis
