I have an Umbraco 6.1.6 site that is running Contour 3.0.26. I recently upgraded the site to Umbraco 6.2.5 and when I did that I missed that some of the Contour config changes had been lost.
To fix this I thought I'd just install Contour and then re-install it. I've tried installing both Contour 3.0.26 and 3.0.27 and with either version I get the following error during install:
Umbraco Contour Installer encountered some errors
Installed the database
Datatype could not be installed +
System.NullReferenceException: Object reference not set to an instance of an object. at Umbraco.Forms.UI.Usercontrols.Installer.Page_Load(Object sender, EventArgs e) in f:\TeamCity\buildAgent\work\fd622d7f786e1305\Umbraco.Forms.UI\Usercontrols\Installer.ascx.cs:line 62
Updated /umbraco/config/create/ui.xml
Added dashboard to Contour application
Updated web.config to use correct asp.net ajax assemblies
Addded Formpicker macro control
Updated english language file with Contour keys
So it's only the datatype that couldn't be installed? It's easy to add that manually, just go to the dev section, datatypes bit and create a new datatype, then select form picker as the render control
Problems installing contour
Does anybody have any ideas?
Comment author was deleted
Thanks. Is there anything in particular that I need to call the data type?
By default it's called insert form but you can choose ...
I've updated the tree.config to the new format and all seems to be working without adding this, thanks.
