When you export a form, it zeroes all of the GUIDS (presumably so that you can create multiple instances from the form template).
Is it possible to set all of the GUIDS in the file so that you can import a form and maintain all of the GUIDs? This is so that we can export forms from dev to live and maintain the GUIDs (which we use in some our Xslt Email transforms, s they don't change, unlike the captions).
Is It Possible To Import Forms and Maintain GUIDs?
Comment author was deleted
If it's for moving between environments you could simply move it on db level
Or I can also share the code that does the export and you can modify it so that it doesn't zero the GUIDS
Thanks for the quick response!
I can manually set the GUIDs, the form is only four fields. Will the import pick up the GUIDs already, or will I need to code my own import?
Looking at the code you'll need to code your own custom import that doesn't clear the id's https://gist.github.com/TimGeyssens/a0a9988a68705cf66800
Thanks Tim! That's given me everything that I need to get this working :)
Super, glad it's working!
