I just upgraded my Umbraco and Contour from a previous version (v4.11.10 for Umbraco, and the version of Contour was so old that it didn't display a version number). Now that everything else is working, I took a look at contour and noticed that the node section is completely empty. some forms are showing up on the right-side panel, so I know that it knows about them.
My user has permission to view Contour, and I checked the trees.config file (everything is in there). I also checked the App_Data\Logs file, and there is nothing in there that shows as an ERROR. I searched for a good while before posting to see if I could resolve it myself, but I haven't been able to find anything else besides what I've already tried. Any help would be greatly appreciated!
Anyone have any idea on this? I still can't get it to work. If I uninstall Contour and then re-install it, will I keep my current forms? This is the only thing I haven't tried yet since I don't want to lose the data we've been gathering with them the past year or so.
Nodes not showing up in contour section (Umbraco 6.2.5, Contour 3.0.27)
I'm using:
Umbraco v6.2.5
Contour version 3.0.27
Comment author was deleted
Mind posting the contents of your config/trees.config file?
Sure! This is what I have for the Contour entries in my trees.config file:
Check out this issue for a fix:
http://issues.umbraco.org/issue/U4-6327#comment=67-19489
