Hi! Do Contour work for mobile registration? I dont get the workflow to work and no entries in the form enteries.
Regard Adam
Comment author was deleted
Yeah it should just work on mobile, once you can submit the form it should trigger the workflows...
Do you see the success message on mobile?
Hi! It´s seems to be trouble when I use table settings from the database, to create a form.
It work´s for mobile if I just make a "normal" form.
Maybe a bug in Contour for Umbraco 6.
Thanks for the reply Tim.
Contour supports Mobile?
Regard Adam
