  • Tom Norwood 29 posts 60 karma points
    Jul 03, 2015 @ 15:58
    Tom Norwood
    PreValue Id is not stored on RecordEventArgs
    Hi!
    I've found what looks like an issue with Umbraco Forms 4.1.4. I have a form with a lookup to a dropdown which is populated by prevalues which pull a list of DataSources. This all looks OK on the form, but when you go to submit the form I cannot see the Id of the PreValue anywhere under the RecordEventArgs object. All I can see is the string value which is the name of the DataSource.
    I need to see the Id so I can retrieve the settings for the DataSource (safely without risking duplicates by going by name).
    Should I raise this on issues.umbraco.org?
    Cheers!
    Tom
    Jul 06, 2015 @ 09:54
    Jul 08, 2015 @ 12:45
    Tom Norwood
    is there any word on if / when this will be fixed?
