  • Joshua D. Stewart 34 posts 84 karma points
    Jan 27, 2010 @ 08:13
    Joshua D. Stewart
    No way to delete/edit Field alias in workflow
    When creating a Workflow step such as "Post form to url" there doesn't appear to be a way to delete a field alias mapping. In addition, if you type a different name for the alias and click update the original alias name doesn't change.
    Jan 27, 2010 @ 08:28
    Joshua D. Stewart
    One bit of clarification. When creating the workflow there is the ability to delete aliases that are created. However, there is no way to delete them once a workflow has been added and you try to go back in and edit it.
  • Per Ploug 865 posts 3491 karma points MVP admin
    Jan 27, 2010 @ 09:28
    Per Ploug
    We have added it to the issue tracker and will include a fix in the next maintance release
    Jan 29, 2010 @ 05:55
    Joshua D. Stewart
    Thank you.
