That allows you to have a formid folder in the \Views\Partials\Forms\ dir (like \Views\Partials\Forms\a585e3e8-61e2-4450-af1f-021a48822ef8) that will allow you to override a specific forms markup
Although I have managed to hack it for now, I will definitely be downloading later tonight and taking a look - sounds like exactly what i wanted, so will test and get back to you.
Topic author was deleted
Customizing for a specific form
Hello People,
I have been trying to do some research into creating custom templates for different forms. Most of the articles I read point here - https://our.umbraco.org/projects/umbraco-pro/contour/documentation/developer/Custom-Markup/ - however this is now outdated since Forms has been updated.
So how would I now create separate template for different forms? Where do I create the new view/partial? Can we still do this?
Hi Stephen,
Unfortunately, this is not possible at the moment with Umbraco Forms but it will be back in the version 4.2.0 of Umbraco Forms,
Try to see TimĀ“s comments in this thread https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/65101-Customising-Umbraco-7-forms
/Dennis
Comment author was deleted
Yup as Dennis mentions this will be back in 4.2, I'll be working on this feature this week so you should be able to upgrade to a nightly build
I'll report back here with more details as soon as that's possible.
Thank you very much guys.
Look forward to seeing the nightly.
Working on it now so will have an update available for you before the end of the day
Ok you can update to the latest nightly
http://nightly.umbraco.org/UmbracoForms/nightlies/
Cheers, Tim
Hi Tim,
Many thanks for this.
Kind Regards, Stephen
