  • Hywel Lewis 37 posts 138 karma points
    Jul 07, 2015 @ 14:16
    Hywel Lewis
    Umbraco forms not setting date/time and giving forms and ID
    Not sure if anyone has come across this but for some reason when I am trying to output a completed Umbraco form entry as transformed XSLT
    This is my code sample;
    Your IP address : <xsl:value-of select="$records/ip"/><br/>
    Record ID : <xsl:value-of select="$records/id"/><br/>
    Updated ID : <xsl:value-of select="$records/updated"/><br/>
    state : <xsl:value-of select="$records/state"/><br/>
    Date created :  <xsl:value-of select="umbraco.library:FormatDateTime($records/created, 'r')"/>
    but for some reason it outputs the following in my email;
    Your IP address : 172.##.#.### (correct ip)
    Record ID : 0
    Updated ID : : 0001-01-01T00:00:00
    State : Submitted
    Date created : Mon, 01 Jan 0001 00:00:00 GMT
    Any suggestions on what may be going wrong?
    cheers Hywel
    Jul 07, 2015 @ 14:19
    Hywel Lewis
    If it helps here is my full xslt file;
    <table style="border-collapse:collapse;border:1px solid black;" width="800">
    <tr style="border:1px solid black;">
        <td valign="top" style="border:1px solid black;padding:5px;font-family:Verdana,Helvetica,Arial,sans-serif;font-size:11px;">
            <strong>
                Updated  : <xsl:value-of select="$records/updated"/><br/>
                State : <xsl:value-of select="$records/state"/><br/>
                <!--****<xsl:copy-of select="$records" />******-->
            </strong>
          </td>
    </tr>
      <xsl:for-each select="$records//fields/child::*">
        <xsl:sort select="./@pageindex" data-type="number" order="ascending"/>
        <xsl:sort select="./@fieldsetindex" data-type="number" order="ascending"/>
        <xsl:sort select="./@sortorder" data-type="number" order="ascending"/>
        <!--<xsl:sort select="@sortorder" data-type="number"/>-->
        <xsl:if test="normalize-space(.//value)">
              <strong>
                <xsl:value-of select="./caption"/>
              </strong>
          </td>
            <xsl:choose>
              <xsl:when test="contains(.//value, '/umbraco/plugins/umbracoContour/files/')">
                <a href="http://{umbraco.library:RequestServerVariables('SERVER_NAME')}{.//value}">
                  <xsl:value-of select="substring-after(substring-after(.//value, '/files/'), '/')"/>
                </a>
              </xsl:when>
              <xsl:otherwise>
                <xsl:for-each select="./values/value">
                  <xsl:if test="position() &gt; 1">
                    <br />
                  </xsl:if>
                  <xsl:value-of select="umbraco.library:ReplaceLineBreaks(.)"/>
                </xsl:for-each>
              </xsl:otherwise>
            </xsl:choose>
          </td>
        </tr>
        </xsl:if>
      </xsl:for-each>
    </table>
  • Comment author was deleted
    Jul 09, 2015 @ 13:09
    Hmm might be a bug, will check and let you know
