  • John C Scott 473 posts 1183 karma points
    Jul 08, 2015 @ 12:56
    John C Scott
    creating very simple custom fieldtype
    using contour 3.0.7 in umbraco 4.11
    i'm trying to add a very very basic extra fieldtype, it's purpose is just to provide a link to more information, so I've based the code on the contrib label type.
    i'm not sure if there is a step I've missed, i've compiled the source (below) into a DLL which is in the sites /bin/ folder and I've added a razor file to \umbraco\plugins\umbracoContour\Views\FieldType.NextAddress.cshtml
    I've restarted the app pool, cleared cache, turned around three times and touched my toes and crossed my legs, fingers and most other superstitious activity. However... my fieldtype does not appear in the list of field types to be added.
    Is there another step I need to take?
    using System;
    using System.Linq;
    using System.Text;
    using Umbraco.Forms.Core;
    using Umbraco.Forms.Core.Controls;
    using System.Web.UI.WebControls;
    using System.Web;
    using Umbraco.Forms.Core.Attributes;
    namespace Equiniti.Web
        class NextAddressLink : FieldType
            public NextAddressLink()
                this.Id = new Guid("c77063d8-ba26-44a9-9871-d0ed238ce72e");
                this.Name = "NextAddress";
                this.Description = "Adds a link to be used for showing an optional additional address.";
                this.Icon = "textfield.png";
                this.DataType = FieldDataType.String;
                this.Value = new List<object>();
            public List<object> Value;
            [Setting("Text To Show", prevalues = "",
               description = "Enter the text to show in the link.",
               control = "Umbraco.Forms.Core.FieldSetting.TextArea")]
            public string TextToShow { get; set; }
            public override WebControl Editor
                get
                    System.Web.UI.WebControls.Panel pnl = new System.Web.UI.WebControls.Panel();
                    pnl.ID = "pnlHolder";
                    pnl.CssClass = "contourlabelfield";
                    pnl.Controls.Add(new System.Web.UI.LiteralControl("<a class=\"nextAddress\" href=\"#\">" + TextToShow + "</a>"));
                    return pnl;
                set
                    base.Editor = value;
            public override List<object> Values
                get
                    Value.Clear();
                    Value.Add(string.Empty);
                    return Value;
                set
                    Value = value;
            public override string RenderPreview()
                return "<a class=\"nextAddress\" href=\"#\">" + TextToShow + "</a>";
            public override string RenderPreviewWithPrevalues(List<object> prevalues)
                return this.RenderPreview();
            public override bool SupportsRegex
                get { return false; }
            public override bool SupportsPrevalues
  • Comment author was deleted
    Jul 08, 2015 @ 14:34
    Did you make sure to give it a unique id? Might be since you copied it's using an id of a fieldtype that is already in place
    Jul 08, 2015 @ 14:36
    John C Scott
    yes - I generated the new ID in Visual Studio
    ah try making your class public
    so class NextAddressLink : FieldType becomes public class NextAddressLink : FieldType
    Jul 08, 2015 @ 15:57
    John C Scott
    oh dear - thank you Tim
    more than slightly embarassed
    thank you very much
