  • Jeff 74 posts 346 karma points
    Jul 09, 2015 @ 13:29
    Jeff
    Salesforce Integration
    I've been looking at using Contour to create a simple form which will post the data to SalesForce, does anyone have an example of how this can be done?
    Jeff
  • Comment author was deleted
    Jul 09, 2015 @ 14:06
    Hey Jeff,
    You can extend Contour with custom workflows so how easy this is will depend a bit on the salesforce api
    For docs on custom workflow types check out https://our.umbraco.org/projects/umbraco-pro/contour/documentation/Developer/Extending-Contour/Adding-a-Workflowtype
    Jul 09, 2015 @ 15:42
    Ismail Mayat
    Tim, I was using older version of contour and for post to url to sales force with prevalue field umbraco documents it was posting ids. So have to write my own post to url workflow, does the latest version post ids or node name? Jeff it may be issue for you if you use prevalues with umbraco documents.
    Regards
    Ismail
