Basically, I've been handed a site that uses Umbraco, I currently don't have access to the hosting.
There is an issue with a contact form - it's not sending emails.
I have found where the form is set up and I have found the workflows - there doesn't appear to be a problem with the settings.
I'm wondering if anybody could tell me if this is likely to be a bug with the version of Umbraco I am using or is most likely to be a server configuration.
Either way, any advice would be gladly appreciated.
At first you should have a look into the web.config file. You can find this file in the root folder of your website on your server. In this file there is a section "system.net" with the smtp-settings:
Can you check if umbraco can send out email notifications? So subscribe to an event (like publish) and then publish a page... if that doesn't work it's definitely a server config issue
Umbraco 4.7.0 not sending emails
Hi All,
I truly am a newbie with Umbraco.
Thanks in advance
Duncan
Hi Dunxmax,
welcome to our :-)
Have you any errors in the umbraco log?
Here you should find your email credentials. If not, please edit the network tag, save the file and try it again.
Hope this helps?
Best, Sören
Comment author was deleted
Hi Duncan,
Thanks for your swift response - I shall attempt to contact the server admin (easier said than done) and I'll get back to you.
Regards
Duncan
