  • Tim 1193 posts 2675 karma points MVP 5x c-trib
    Jan 28, 2010 @ 12:40
    Tim
    ValidationGroup
    Contour doesn't appear to assign it's controls to a validationgroup. This is fine if you have only one form on the page, but if for example you have a login box in the header of every page (and that isn't assigned to a validationgroup), then the contour form will fire the login form's validation controls in addition to its own and vice versa.
    Are there any plans to make Contour assign it a validation group to its validation controls (or perhaps make it something you can define for the form)?
