  • Ayo Adesina 445 posts 1059 karma points
    Jul 21, 2015 @ 09:09
    Ayo Adesina
    Where is are work flows stored - Umbraco Forms
    I'm Using SQL CE for a project
    I pulled down the db file on to my computer to make some changes to the work flow in forms, after making my changes and uploading the DB...
    The work flows I have updated do not seem to show on live...
    What other files do I need to upload?
    Jul 21, 2015 @ 09:13
    Dennis Aaen
    101
    Hi Ayo,
    If you go to your Umbraco installations file structure you will find the Workflows folder in the \App_Plugins\UmbracoForms\Data\Workflows
    Hope this helps,
    /Dennis
