Mind providing test results? You can hook in your own date picker, currently we are just using the jquery ui one which is a commonly uses one (so strange that that doesn't pass)
We hired disabled users to go through the site.
They use keyboard and a screen reader to go through the site.
the date picker text field is keyboard accessible but the popup is not.
Topic author was deleted
wcag datepicker contour
we have test users for WCAG and the datepicker does not pass WCAG. is there a setting i am supposed to do?
Umbraco Contour version 3.0.18 Umbraco v6.2.4
Comment author was deleted
Hello Tim,
We hired disabled users to go through the site. They use keyboard and a screen reader to go through the site. the date picker text field is keyboard accessible but the popup is not.
Fortunately, I have had experienced creating a custom fields in contour so I will just use this sample: http://www.oaa-accessibility.org/example/15/
We have decided to upgrade the site to umbraco 7 and I hope it is similar to building custom fields in contour.
https://github.com/avatart0ph/umbracoupgrade6to7/tree/master/customizations/WCAGDatePicker%20-%20Umbraco%20Forms
