  • Tim 1193 posts 2675 karma points MVP 5x c-trib
    Feb 04, 2010 @ 18:25
    Tim
    Workflow Not Showing In Contour
    I've created a workflow, using the template in the documentation. I've given it a new GUID, and removed the settings (the task carries out some maintenance stuff that doesn't need any settings). However the Workflow isn't showing up in the dropdown when I add a workflow.
    The workflow compiles ok, and I'm not getting any errors, so I'm a bit stumped as to why it isn't appearing in the list. The class is in a DLL with a couple of other related classes (utility classes for the task, and a publishEvent, which is being picked up by Umbraco correctly). Does anyone have any ideas why a workflow wouldn't show up in the list?
  • Harald Ulriksen 207 posts 249 karma points
    Feb 05, 2010 @ 11:31
    Harald Ulriksen
    Can you post any source?
    Best regards,
    Harald
    Feb 05, 2010 @ 12:27
    Tim
    Sure:
    using
    System;
    using
    System.Collections.Generic;
    using
    System.Linq;
    using
    System.Text;
    using
    umbraco.BusinessLogic;
    using
    umbraco.cms.businesslogic.web;
    using
    Umbraco.Forms.Core;
    using
    Umbraco.Forms.Core.Enums;
    namespace
    Epiphany.AskAnExpert
    /// <summary>
    /// Workflow class to publish a question to the AAE area of the site for approval
    /// </summary>
    class PublishQuestion : Umbraco.Forms.Core.WorkflowType
    public PublishQuestion()
    this.Id = new Guid("de889e2d-1c28-4767-a0ef-eee75216a8ab");
    this.Name = "Publish Ask An Expert Question";
    this.Description = "Publishes the form as an ask an expert question on the site";
    public override List<Exception> ValidateSettings()
    return new List<Exception>();
    public override WorkflowExecutionStatus Execute(Record record, RecordEventArgs e)
    //create new page and map the form to it
    //Get the type you would like to use by its alias
    //and the user who should be the creator of the document
    DocumentType dt = DocumentType.GetByAlias("AskAnExpertQuestion");
    umbraco.BusinessLogic.
    User author = umbraco.BusinessLogic.User.GetUser(0);
    string question = record.RecordFields[new Guid("96d62921-70b7-457f-9c23-d356ba6abef8")].ValuesAsString();
    string background = record.RecordFields[new Guid("a932b211-4222-4cd1-8bc3-6464c644fba2")].ValuesAsString();
    string area = record.RecordFields[new Guid("a1c6e101-da6d-4d3e-beb2-5e4198804562")].ValuesAsString();
    string firstName = record.RecordFields[new Guid("e76ed39d-0f60-4f75-9426-ee8f0b422efa")].ValuesAsString();
    string surname = record.RecordFields[new Guid("8da8815a-fadb-4dfb-8587-ed4ea269f89b")].ValuesAsString();
    string screenName = record.RecordFields[new Guid("d6cddf93-4235-4712-9cc3-46f0881114fa")].ValuesAsString();
    string emailAddress = record.RecordFields[new Guid("6490dab3-d70f-4a56-890c-abd88685a1c2")].ValuesAsString();
    //get page name. If the question is longer than the maximum allowed, shorten it to the first sentence
    string pageName = question;
    if (pageName.Length > 150)
    if (pageName.IndexOf(".") > 0)
    pageName = pageName.Substring(0, pageName.IndexOf(
    else
    pageName = pageName.Substring(0, 150);
    pageName = pageName.Substring(0, pageName.LastIndexOf(
    " ")).Trim();
    //create a document with a name, a type, an umbraco user, and the ID of the document's parent page.
    //To create a document at the root of umbraco, use the id -1
    Document doc = Document.MakeNew(pageName, dt, author, Convert.ToInt32(area));
    doc.getProperty(
    "question").Value = question;
    doc.getProperty(
    "background").Value = background;
    doc.getProperty(
    "firstName").Value = firstName;
    doc.getProperty(
    "surname").Value = surname;
    doc.getProperty(
    "displayName").Value = screenName;
    doc.getProperty(
    "emailAddress").Value = emailAddress;
    //after creating the document, save it, but don't publish it
    doc.Save();
    //return the completed status
    return WorkflowExecutionStatus.Completed;
    Feb 05, 2010 @ 12:59
    Harald Ulriksen
    Try to mark your class as public. As far as I can remember the default access modifier in C# is internal, hence it cannot be accessed by an other assembly.
    Feb 05, 2010 @ 13:15
    Tim
    Ahah, that was it! I am a tool, I should have spotted that earlier, thanks!
    Feb 05, 2010 @ 13:38
    Harald Ulriksen
    Excellent, can you please mark this topic as solved?
    Harald.
