  • Søren Kottal 713 posts 4571 karma points MVP 6x c-trib
    Aug 05, 2015 @ 09:00
    Søren Kottal
    Save to input specific node using xpath in contour
    Is it possible to make an xpath to save a new document in a node relative to one of the form fields?
    Like //Submissions/Category[name=$formfield]
  • Comment author was deleted
    Aug 05, 2015 @ 09:30
    Hmm not sure will have to check the code for that but in case it works it should be the with the following syntax //Submissions/Category[name=[$formfield]]
    so[$formfield] will be replaced
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 8x admin c-trib
    Aug 10, 2015 @ 09:09
    A quick "outside" observation: Using square-brackets as part of the replacement could potentially be a problem, since the XPath itself will be invalid...
    Any specific reason for having to use them like that?
    /Chriztian
    Aug 11, 2015 @ 08:02
    @Chriztian, well the replacement will happen on the string before it is used as an xpath statement
    Aug 11, 2015 @ 08:14
    hehe - I'm totally aware of that, didn't mean to sound as if I didn't get it :)
    It's just that in other places where XPath is used (e.g. the MNTP) they're just "magic variables" – here, you also need to wrap them in square brackets, which has their own meaning in XPath - so can be potentially confusing if you've started to get familiar with XPath for some of the places it can be used...
    Really, I was probably more concerned about the consistency-issue than the XPath-issue here.
    /Chriztian
    Aug 05, 2015 @ 09:32
    Currently it won't work but it's an easy update if you are up for upgrading to a nightly?
    Aug 05, 2015 @ 09:39
    Just made the changes, you can upgrade to 3.0.29 WIP build that available here http://nightly.umbraco.org/Umbraco%20Contour/3.0/UmbracoForms.files.3.0.29.WIP-Build.50.zip
    Aug 06, 2015 @ 13:05
    Søren Kottal
    Thanks, I will look into that!
    Aug 10, 2015 @ 08:32
    So did that do the trick?
    Aug 19, 2015 @ 06:25
    Søren Kottal
    Unfortunately, I haven't been able to upgrade yet.
