I'm just wondering if it is possible to search + display contour form submissions?
I know that the submissions get stored in the DB. Can i use the API to access the form submissions that match a certain query string for example?
Kind regards,
James.
Ended up using the API here :
https://our.umbraco.org/projects/umbraco-pro/contour/documentation/Developer/Working-with-Contour-data-in-Razor/
It is possible to search for data that matches a query string .
Searching + Displaying Contour Submissions
Kind regards,
James.
