Is there any documentation about the Classes in the Umbraco Forms libraries? I'm trying to implement some custom Workflows and having a hard time determining without the comments and/or documentation.
Hi JJ,
Did you see the documentation for Umbraco Forms about how to add a custom workflow?
https://our.umbraco.org/documentation/Add-ons/UmbracoForms/Developer/Extending/Adding-a-Workflowtype
Hope this helps,
/Dennis
Thanks Dennis, that's the example I'm using, but it doesn't go into any detail about the library.
If you are in Visual studio you can get a list of the different classes in Umbraco.Forms.Core by using the object browser.
Umbraco.Forms.Core
Hi JJ,
Hope this helps,
/Dennis
Hi JJ,
Hope this helps,
/Dennis
