If logging in to get the license isn't working out, I would try just taking the umbracoForms.lic file and dumping it into the bin. I believe that when you log in through the backoffice like that, all it is trying to do is download a license to the bin directory. You can dump it in manually if you can get your hands on that umbracoForms.lic file.
Can not use Contour
I have added Contour to my project. When I enter my login detail on the Contour dashboard I get following error,
"Couldn't connect to umbraco.org This could be because your credentials are wrong or because you're not online."
We have purchased Umbraco pro version. I can use login on the Umbraco.tv to watch the videos.
I installed Contour as local package. Do I need to configure any file/folder?
This has resolved the issue. Thanks for your help.
