I need to add a Contour Form onto a Grid Layout and it seems like this is not possible ?
I choose Macro, Insert Form from Umbraco Contour (Razor) and then my form, but when rendered, we simply see the following rendered.
<Macro: (,)>
I have added Contour forms to the RTE many times using the same macro without issue.
I have exactly the same issue https://our.umbraco.org/forum/umbraco-pro/contour/70699-macro-alias-umbracocontourrazorrenderform-not-displaying-since-upgrade-to-v7 so you're not alone!
Rendering Contour Form in Umbraco 7.2.2 Grid Layout
