  • Jinesh 15 posts 95 karma points
    Aug 19, 2015 @ 11:35
    Jinesh
    Umbraco form PROBLEM
    What is oledb Compatable connection string for sql server compact (default) database.
    normal connection string (got from server explorer db properties) is :
    "Data Source=C:\UmbracoDemo\App_Data\Umbraco.sdf"
    connection string in web.config is
    <connectionStrings>
        <remove name="umbracoDbDSN" />
        <add name="umbracoDbDSN" connectionString="Data Source=|DataDirectory|\Umbraco.sdf;Flush Interval=1;" providerName="System.Data.SqlServerCe.4.0" />
        <!-- Important: If you're upgrading Umbraco, do not clear the connection string / provider name during your web.config merge. -->
      </connectionStrings>
    Tnxx
    Aug 21, 2015 @ 08:02
    Nik
    The connection string in your web config is more dynamic than the one you got from Server Explorer.
    |DataDirectory| tells the system to look for the app_data directory in the current directory of the application, in this case your website. At least that is my understanding.
