I've upgraded our v6 website to v7 but Contour is failing to work.
If I go to edit a page with a form on it, it is displaying
Macro alias: umbracoContour.RazorRenderForm
where the form should be rather than the form and if I go to browse the actual page, I get
<Macro: (,)>
instead of the form.
I upgraded to v7.2.8 and I have installed the latest version of Contour (3.0.28)
Same problem, did you fixed it?
Please let me know
Turned out I had two "Insert form from Umbraco Contour" Macros so Umbraco was getting confused.
Thanks for your quick response :)
I have 3 different macros 1) Insert form from Umbraco Contour 2) Insert form from Umbraco Contour (Razor) 3) Insert form from Umbraco Contour (Usercontrol)
which one i need to delete?
You want the one that has MvcRenderContourForm.cshtm in the Razor script field
Macro alias: umbracoContour.RazorRenderForm not displaying since upgrade to v7
Please let me know
