I've added a checkbox setting to a custom FormDataSourceType:
[Umbraco.Forms.Core.Attributes.Setting("CreateRecord", view = "CheckBox")] public bool CreateRecord { get; set; }
When you save the data source and the setting is true the form fails to save. there is nothing in the umbraco logs. Running umbraco forms Umbraco Forms 4.2.0-WIP.Build.65.
See: http://issues.umbraco.org/issue/CON-821
Comment author was deleted
Hey, it's because CreateRecord can't be used as a property name, renaming it should get rid of the error
BUG: Adding checkbox setting to custom FormDataSourceType does not work
