Umbraco Forms validation for custom settings types
I'm building an Umbraco Forms 4.1.1 solution for a client, and we are building some custom setting types for this solution.
Our setting types are being rendered correctly and the data is being stored and received as expected.
I am now trying to add some validation for these fields and prevent closing the settings pane if the fields cannot be validated.
I see nowhere in the documentation on how to achieve this behavior, is it at all possible or is there workarounds that doesn't involve messing about the Umbraco Forms scripts?
Did you ever find a solution for this?
Ben
