  • Gal Nitzan 50 posts 164 karma points
    Oct 07, 2015 @ 20:47
    Gal Nitzan
    How to create custom forms and controls in Umbraco Forms
    Hello, I have Upgraded to Umbraco Forms latest from Contour on 7.2.8 without any problem thanks for the migration package by Tim Geyssens.
    Previously I had a few custom forms and controls as outlined by Tim
    Since there is no plugin any more, how can I achieve the same functionality?
    Just from the top of my head I tried to create folders with the form Id as it was before under Views\Partials\Forms but it didn't work :(.
    Any suggestion would be appreciated.
    BR'
    Gal.
    Oct 08, 2015 @ 06:34
    Dennis Aaen
    Hi Gal,
    It will be possible to create customs forms again in Umbraco Forms version 4.2.
    If you need the option right now, what you can do then is to using the latest nightly of Umbraco Forms build. It has the feature.
    You can find the latest nightly build of Umbraco Forms here http://nightly.umbraco.org/UmbracoForms/nightlies/
    Hope this helps,
    /Dennis
    Oct 08, 2015 @ 09:25
    Gal Nitzan
    Hi Dennis,
    Thank you so much for the solution !
    Had to do a small change in my old code, however works as expected.
    Gal.
