Installation problems of Contour 3.0.28 under Umbraco v7.2.8
I was just about to install Contour for a new site I'm making and I got the following message on the screen on which you have to confirm the installation and the adding of new binaries:
Legacy Property editors detected
Read more...
This package contains legacy property editors which are not compatible
with Umbraco 7
This package may not function correctly if the package developer has
not indicated that it is compatible with version 7. Any DataTypes this
package creates that do not have a Version 7 compatible property
editor will be converted to use a Label/NoEdit property editor.
So I'm a bit hesitant about going through with the installation. Can I just install without worrying or should I really leave it?
Hi, I was just about to install Contour for a new site I'm making and I got the following message on the screen on which you have to confirm the installation and the adding of new binaries:
All the best
Jan
Hi Jan
If you have a valid contour licence and starting afresh I would recommend using forms over contour.
Otherwise it should run, albeit with a rather clunky UI.
Martin
