I am using the reCaptcha module posted here.
Is there a way to implement custom translations?
I tried adding a
var RecaptchaOptions = { custom_translations : {} };
in the header, but I can see that it gets overridden when the reCaptcha module is rendered.
Comment author was deleted
Hi Ove,
I think you can do this with some js, check out the documentation on the recaptcha site
http://recaptcha.net/apidocs/captcha/client.html
I tried, but the problem is that the javascript is ignored.
Hi Ove, think you will have to modify the sourcecode of the reCaptcha fieldtype then
Custom translations for reCAPTCHA
I tried adding a
var RecaptchaOptions = {custom_translations : {} };
Hi Ove,
