  • Jan Vanuytrecht 32 posts 80 karma points
    Nov 04, 2015 @ 10:22
    Jan Vanuytrecht
    RecordStorage InsertRecord method requires HttpContext.Current.Request, which is not always available
    We have code to migrate our "old" contour records to Umbraco forms.
    Something like :
    Code
     foreach (var umbracoFormRecord in umbracoFormRecords)
             // create the record
             recordStorage.InsertRecord(umbracoFormRecord, umbracoForm);
    We can't do this, because the current line in the Umbraco.Forms.Data.Storage.RecordFieldValueStorage class uses the Licensing.IsLocalBrowserRequest() check. The result is not used anywhere though !?
    Umbraco.Forms.Data.Storage.RecordFieldValueStorage:
    bool flag = Licensing.IsLocalBrowserRequest();
    which translates into:
    Umbraco.Forms.Core.Licensing:
    public static bool IsLocalBrowserRequest()
        return HttpContext.Current != null && HttpContext.Current.Request.IsLocal;
    And there's the problem: HttpContext.Current.Request ... Which means we can't use this in the ApplicationStarting event.
    Much worse, you can't do this in any (Web)ApiController!
    I've logged an issue here : http://issues.umbraco.org/issue/CON-846
