No provider with id '57add3ab-c3cd-464d-bcc2-3d1c05d3bf67' found
Exception Details: Umbraco.Forms.Core.Common.ProviderException: No provider with id '57add3ab-c3cd-464d-bcc2-3d1c05d3bf67' found
Source Error:
Stack Trace:
[ProviderException: No provider with id '57add3ab-c3cd-464d-bcc2-3d1c05d3bf67' found]
Umbraco.Core.Cache.HttpRuntimeCacheProvider.GetCacheItem(String cacheKey, Func`1 getCacheItem, Nullable`1 timeout, Boolean isSliding, CacheItemPriority priority, CacheItemRemovedCallback removedCallback, CacheDependency dependency) +1063
Umbraco.Core.CacheHelper.GetCacheItem(String cacheKey, CacheItemPriority priority, CacheItemRemovedCallback refreshAction, CacheDependency cacheDependency, TimeSpan timeout, Func`1 getCacheItem) +587
umbraco.cms.businesslogic.cache.Cache.GetCacheItem(String cacheKey, Object syncLock, CacheItemPriority priority, CacheItemRemovedCallback refreshAction, CacheDependency cacheDependency, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem) +325
umbraco.cms.businesslogic.cache.Cache.GetCacheItem(String cacheKey, Object syncLock, CacheItemPriority priority, CacheItemRemovedCallback refreshAction, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem) +111
umbraco.cms.businesslogic.cache.Cache.GetCacheItem(String cacheKey, Object syncLock, CacheItemRemovedCallback refreshAction, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem) +108
Umbraco.Forms.Core.Services.CacheService.GetCacheItem(String cacheKey, Object syncLock, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem) in f:\TeamCity\buildAgent\work\fd622d7f786e1305\Umbraco.Forms.Core\Services\CacheService\CacheService.cs:62
Umbraco.Forms.Data.Storage.FormStorage.GetAllForms(Boolean archived) in f:\TeamCity\buildAgent\work\fd622d7f786e1305\Umbraco.Forms.Core\Data\FormStorage\FormStorage.cs:49
Umbraco.Forms.UI.Dashboard.FormsDashboard.Page_Load(Object sender, EventArgs e) in f:\TeamCity\buildAgent\work\fd622d7f786e1305\Umbraco.Forms.UI\Dashboard\FormsDashboard.ascx.cs:53
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +188
System.Web.UI.Control.OnLoad(EventArgs e) +162
System.Web.UI.Control.LoadRecursive() +164
System.Web.UI.Control.LoadRecursive() +262
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3573
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.34274
I am getting above error after upgrading to latest version.
Does anyone knows how to fix it
I'ts a bit late now, but I just ran into the same error message just after I upgraded Umbraco to v7.15.7.
I over enthusastically copied the bin folder from the new version forgetting all the extra DLLs installed on the old version.
These included contourcontrib.dll which when I copied back the error disappeared. Presumably, this DLL implemented the provider as well as others.
57add3ab-c3cd-464d-bcc2-3d1c05d3bf67 seems to be a CAPTION fieldtype
I am getting above error after upgrading to latest version. Does anyone knows how to fix it
Please let me know
Thanks, Lokesh
Finally fixed it by deleting rows from UFFields table where Fieldtype is '57add3ab-c3cd-464d-bcc2-3d1c05d3bf67'
Hi Lokesh
what impact did deleting rows from UFFields table where Fieldtype is '57add3ab-c3cd-464d-bcc2-3d1c05d3bf67' have?
I've just had the same error and wouldn't want to have to add a missing field back into all/many of my online forms
Steve
Hi Steve,
I have upgraded successfully without any bugs even after deleting rows from UFFields. (All my forms are working)
I think '57add3ab-c3cd-464d-bcc2-3d1c05d3bf67' is an ID for label fieldtype in an older version which is changed in newer version.
My suggestion is to try it on local version and check the forms
Please don't forgot to take back up before experimenting
Lokesh
I'ts a bit late now, but I just ran into the same error message just after I upgraded Umbraco to v7.15.7. I over enthusastically copied the bin folder from the new version forgetting all the extra DLLs installed on the old version. These included contourcontrib.dll which when I copied back the error disappeared. Presumably, this DLL implemented the provider as well as others.
