Hi Guys,
So I have an issue, what I want to do is make forms that users can start doing but may want to come back to, if that makes sense?
What I want to know is can Forms or Contour do this, and if so what do i need to make it work?
I'm familiar with the way they work as i have used both of them in different projects.
Nathan
Ok I have come up with another solution, im going to use jQuery Save As You Type instead, This does what i need.
Hi Nathan,
I have found a similar topic for Umbraco Contour. https://our.umbraco.org/forum/umbraco-pro/contour/44630-Contour-Saving-a-multi-part-form-for-later-editing
I think that you can do something similar to Umbraco Forms. But just be sure that if you are using multi steps forms that you are using the latest nightly build Umbraco Forms 4.2 regarding to this issue. http://issues.umbraco.org/issue/CON-733
Hope this helps,
/Dennis
Upload image
Contour or Forms
Hi Guys,
Nathan
Nathan
Hi Nathan,
Hope this helps,
/Dennis
