  • Dan Evans 631 posts 1018 karma points
    Dec 22, 2015 @ 17:34
    Dan Evans
    Conditions with checkbox in Umbraco Forms
    Running 7.2.8
    Trying to create a form with conditions based on a checkbox being checked but nothing is happening.
    If I set a text field to "Show" when the checkbox is "true" then nothing happens, checked or not it always shows.
    If I set it to hide then it is always hidden regardless of the checkbox.
  • Pradip 24 posts 116 karma points
    Dec 31, 2015 @ 05:59
    Pradip
    I think umbraco will not set first condition(default one) when you update field (It will reset to first field)so that we need to set another (second) condition for checkbox.
    Please see the below screenshot which helps you a lot. In this, I have check checkbox condition if true then show Message text field otherwise hide it.
