In Contour, it was possible to create a custom view for a single form, usually by taking the general form template, copying, and modifying it as needed. I've tried creating ~/Views/Partials/Forms/{guid}/Form.cshtml, but it doesn't get picked up, and just defaults back to ~/Views/Partials/Forms/Form.cshtml
So as a bad workaround, I've got conditional blocks all over that shared file checking to see if the FormID is the one I need, but I'm wondering if there's just some place else I need to be putting the file for it to work.
The custom markup view for a specific form, is not available in the version of Umbraco Forms 4.1.4, but it will be back in the next version of Umbraco Forms 4.2.
If you need the option right now, what you can do then is using the lastet nightly build of Umbraco Forms version 4.2 which can be found here.
You can install the package, but if you already have forms, then you should use the UmbracoForms.Files.4.2.0-WIP.Build.77.zip and the override the existing files
Umbraco Forms: Custom view
Umbraco 7.3.4 with Forms 4.1.4
Hi Carl,
http://nightly.umbraco.org/?container=umbraco-forms-nightlies
/Dennis
Hm, OK. I'll just leave my hack in place for now then and wait for 4.2 stable to be released with a full changelog so we can test it. Thanks.
