  • Tobi 7 posts 87 karma points
    Feb 02, 2016 @ 10:20
    Tobi
    Problem Updating Umbraco Forms
    Hi Our! I'm having problems updating umbraco forms. We were using umbraco forms 4.1.4 on Umbraco 7.2.6. Then I read about a security issue in forms. So I used the update button in the forms section in umbracos backend, but the update never seemed to finish. And now our forms are not working anymore. In the developer section -> installed packages it still says: UmbracoForms.Package.4.1.4. But the file "App_Plugins\UmbracoForms\UmbracoForms.config" states this: settings version="4.1.5"
    I'm guessing the update didn't go through (due to rights problems or something). Is there a (updated) guide for updating forms manually? Unfortunately this page (https://our.umbraco.org/projects/developer-tools/umbraco-forms/) doesn't contain any information on how to update. And I'm not sure if this one (https://our.umbraco.org/projects/umbraco-pro/contour/documentation/Installation/Manual) is up-to-date as it still refers to "Contour". Anyway, I hope I just need to "finish" the update and then forms will work again. Any suggestion as to how to achieve this?
    Kind regards, Tobi
    Feb 02, 2016 @ 12:25
    Dennis Aaen
    Hi Tobi,
    What you can do to upgrade UmbracoForms manually this will not affecting any existing forms. The only thing you should be a aware of is if you have made any customization to the views.
    If not, then you can download UmbracoForms.Files.4.1.5.zip http://nightly.umbraco.org/UmbracoForms/4.0/UmbracoForms.Files.4.1.5.zip and simply just overrides the files with the new once.
    The form enteties is in the DB, and your existing forms is in the folder App_Plugins/UmbracoForms/Data/forms and this folder is not in the upgrading zip file.
    Hope this helps, and make sense.
    /Dennis
