  • Laith 6 posts 46 karma points
    Feb 02, 2016 @ 17:50
    Laith
    Generate razor for contour form
    I've created a contour form and inserted into a template using: @Umbraco.RenderMacro("umbracoContourRazorRenderForm", new {FormGuid="..."})
    This generates a macroscript although it doesn't contain any meaningful razor code which I can add classes etc It just contains an Html.RenderMvcAction passing in action, controller, formGuid, formtoken etc
    When I inserted my contour form into the template I selected "Insert from Umbraco contour".
    In this video: http://umbraco.com/follow-us/blog-archive/2012/11/8/contour-30-features-full-control-over-form-markup/
    After watching the following video I noticed there is also a "razor contour form" option @1.42 although I don't have this option. Later @ 2.02 he shows the razor code.
    How do I generate the razor code?
    I'm using Umbraco version 7.3.5 and Umbraco Contour version 3.0.28
    Feb 02, 2016 @ 20:42
    Hi Laith
    If I remember correctly you should be able to find the partials for Umbraco Contour in the /Views/Partials/Forms folder where you can see the view for the form itself and the different input types that a form can consist of.
    Is this what you're looking for?
    Feb 02, 2016 @ 21:44
    Dennis Aaen
    Hi Laith,
    Since you are using Contour you should have a look at this documentation https://our.umbraco.org/projects/umbraco-pro/contour/documentation/Developer/Custom-Markup/
    The views can be found in the ~\Umbraco\plugins\umbracoContour\Views directory
    And you also have the option to create custom markup for a specific form, so your all forms donĀ“t need to contain the same markup.
    Hope this helps,
    /Dennis
    Feb 10, 2016 @ 10:04
    Laith
    Thanks Dennis, the section "Customizing for a specific form" is exactly what I was after!
