With a contour form on. In the top there is a member login form. When posting the contour form it tries to validate the login fields. I found a post about validation groups and have put that on the login fields and the login button ( hidden with css ), but still it gets validated when posting the contour form. Any body know what else can be the problem or how to solve it?
When you developed contour did you test with both a contour form and another asp.net static post button and test the validation? As i dont think its a problem in my code as i cant add validation groups to more controls and its still having the problem. Maybe contour should have a validation group so it dont break other forms on the page?
When i dont have validation groups on the login form the login fields is also validated when i submit the contour form by asp.net client validation and shows small * error text. When i put validation group on the login control its only the contour fields that gets validated by client validation. BUT then on the postback it validates the login form as well and the * error message displays for the login control.
Is that because of contour not having validationGroup or something about my static form?
Like Anders, when is the next maintenance release scheduled? I'm running into this very same situation (newsletter signup & contact form). I've removed all validators from the Contour forms and will likely create my own validationGroup-like activity through jQuery.
I am also having the same issue.. and it is not something i can fix using css to hide the elements etc.. We really need this fixed as we rely on validation groups and the client has requested the use of contour
Tim has confirmed that this is fixed in the next release, but i said it would be published almost 2 weeks ago. Tim any progress on the release of the maintenance release?
Problems with 1 contour form and an asp.net form and validation groups
I have this page
http://www.globalwindpower.dk/da/technical--commercial-management/gratis-sundhedstjek/bestillingsformular.aspx
I can post code if you need it :)
Comment author was deleted
That should do the trick. Do the login name validator, password validator and login button all have the same validation group ?
Yes they have - thats the weird about it all. Its inside an asp.net login control and in the "anonymous" template
Any idea Tim?
Think it might be related to the onsubmit attribute on your form tag
Hi Anders, yes that has been tested, if the other forms have a validation group it should work fine.
But to avoid this in the future, we'll add validation groups to the validators used by a Contour form in the next maintenance release.
When is the maintenance release scheduled for?
Is it possible for you to make a simple test with a login control form and a contour form?
I have tested some more.
I was a little to fast. Here is a post where Tim says the 1.09 version of contour is out.
http://our.umbraco.org/forum/umbraco-pro/contour/8260-Pagename-in-Contour-Email-workflow?p=0#comment30637
Tim could you make a blog post about it or how do you notify people of new releases? Also the minor releases is important to us, as it fixes bugs
@Anders, we are working on an update of umbraco.org where it will be possible to easily keep track of the product releases.
Hi I was just wondering where do we actually download the upgrades from.. I can't seem to find out where to even get 1.09 from..
can we confirm that this version fixes the bug?
Tom
Hi Tom,
You can get it from here http://nightly.umbraco.org/Umbraco%20Contour/1.0.9/
Pretty sure this version fixes this bug, as it is noted in changes.txt
Neil
