I have made this custom WorkFlowType for a customer and work as intended when i run it locally, but when i put it on the live server it wont execute.
The way i published it was to make a new build and take the dll and put it on the FTP. I then created a new WorkFlowType of my custom type and added it to a existing form. I then tested the form in the contour backend. Since this didnt work (on live, it worked when i debugged locally), i tried added one of the default workflowtypes (Send Mail) and made sure it was placed after my custom workflowtype. The "Send Mail"-workflow was runned but mine wasnt and nothing was in the log (check the code for log outputs). I then tried moving the .cs-file of my custom workflowtype to the "App_Code"-directory on the live site, but this didnt chance anything.
Any suggestions?
Umbraco v6.1.6 (Assembly version: 1.0.5021.24867)
Umbraco Contour version 3.0.18
public class AttachStaticPdfToMailWorkType : WorkflowType
private static readonly ILog Log = LogManager.GetLogger(MethodBase.GetCurrentMethod().DeclaringType);
[Umbraco.Forms.Core.Attributes.Setting("Email",
description = "Enter the receiver email",
control = "Umbraco.Forms.Core.FieldSetting.TextField")]
public string _Email { get; set; }
[Umbraco.Forms.Core.Attributes.Setting("SenderEmail",
description = "Enter the sender email (if blank it will use the settings from /config/umbracosettings.config)",
public string _SenderEmail { get; set; }
[Umbraco.Forms.Core.Attributes.Setting("Subject",
description = "Enter the subject",
public string _Subject { get; set; }
[Umbraco.Forms.Core.Attributes.Setting("Message",
description = "Enter the intro message",
control = "Umbraco.Forms.Core.FieldSetting.TextArea")]
public string _Message { get; set; }
[Umbraco.Forms.Core.Attributes.Setting("Attachment file", description = "Attach a file to the e-mail", control = "Umbraco.Forms.Core.FieldSetting.File")]
public string _AttachmentFile1 { get; set; }
[Umbraco.Forms.Core.Attributes.Setting("Attachment file (2)", description = "Attach a file to the e-mail", control = "Umbraco.Forms.Core.FieldSetting.File")]
public string _AttachmentFile2 { get; set; }
public AttachStaticPdfToMailWorkType()
this.Name = "Send email (with attachments)";
this.Id = new Guid("f8e45f17-6b05-4678-bcf3-6c031d62983e");
this.Description = "Send the result of the form to an email address (with attachments)";
Log.Info("AttachStaticPdfToMailWorkType - Init");
public override WorkflowExecutionStatus Execute(Record record, RecordEventArgs e)
try
Log.Info("AttachStaticPdfToMailWorkType - Start");
Log.Info("AttachStaticPdfToMailWorkType - Success");
return WorkflowExecutionStatus.Completed;
catch (Exception ex)
Log.Error("AttachStaticPdfToMailWorkType - Failed", ex);
return WorkflowExecutionStatus.Failed;
public override List<Exception> ValidateSettings()
var result = new List<Exception>();
if (String.IsNullOrWhiteSpace(_Email)) result.Add(new Exception("Email is empty"));
if (String.IsNullOrWhiteSpace(_Subject)) result.Add(new Exception("Subject is empty"));
if (String.IsNullOrWhiteSpace(_Message)) result.Add(new Exception("Message is empty"));
return result;
Contour Custom WorkFlowType not running on live
Hey all,
Any suggestions?
Nvm - I solved it by putting the code in a seperate class library and added the needed reference:
I then build the dll and put it in my bin folder on the live site
