What you can do to be able to customize the email, is to use the Send xslt transformed email workflow. With this you have full control over the email contents by supplying an xslt file.
If you can let me know if you are using Contour or Umbraco Forms, then I can guide you a bit more.
This is great but it's not quite what I need. When using the standard send email there is a message field for users to complete a message to the user. We can then use the {bracket} syntax to add in the particular form fields we want to include in the email. So all we really want to do is remove the data dump at the end of this email.
Alternatively, using the XSLT as you recommend, how would I add in a custom message from the user and use the {bracket} syntax? There is no message box when this option is selected.
If you choose to use the XSLT approach you donĀ“t have the thank you message field. You should be able to use the {bracket} syntax to add in the particular form fields in the thank you message field.
Here is the amended workflow - just drop it in App_Code or compile as a dll.
using System;
using System.Linq;
using System.Text;
using Umbraco.Forms.Core.Enums;
using System.Text.RegularExpressions;
using Umbraco.Forms.Data.Storage;
using System.Xml;
using System.Xml.XPath;
using System.Web;
using System.Net.Mail;
namespace Umbraco.Forms.Core.Providers.WorkflowTypes
public class SendEmailNoData : WorkflowType
[Attributes.Setting("Email", description = "Enter the receiver email", view = "TextField")]
public string Email { get; set; }
[Attributes.Setting("SenderEmail", description = "Enter the sender email (if blank it will use the settings from /config/umbracosettings.config)", view = "TextField")]
public string SenderEmail { get; set; }
[Attributes.Setting("Subject", description = "Enter the subject", view = "TextField")]
public string Subject { get; set; }
[Attributes.Setting("Message", description = "Enter the intro message", view = "TextArea")]
public string Message { get; set; }
[Attributes.Setting("Attachment", description = "Attach file uploads to email", view = "Checkbox")]
public string Attachment { get; set; }
public SendEmailNoData()
this.Id = new Guid("32ee1bc2-afcd-4bab-a3af-a28ca97bef85");
this.Name = "Send email without form data";
this.Description = "Send the result of the form to an email address";
public override List<Exception> ValidateSettings()
List<Exception> l = new List<Exception>();
if (string.IsNullOrEmpty(Email))
l.Add(new Exception("'Email' setting has not been set"));
if (string.IsNullOrEmpty(Message))
l.Add(new Exception("'Message' setting has not been set'"));
return l;
public override WorkflowExecutionStatus Execute(Record record, RecordEventArgs e)
System.Net.Mail.MailMessage m = new System.Net.Mail.MailMessage();
m.From = new System.Net.Mail.MailAddress(string.IsNullOrEmpty(SenderEmail) ? umbraco.UmbracoSettings.NotificationEmailSender : SenderEmail);
m.Subject = Subject;
m.IsBodyHtml = true;
if (Email.Contains(';'))
string[] emails = Email.Split(';');
foreach (string email in emails)
m.To.Add(email.Trim());
else
m.To.Add(Email);
//RecordsViewer viewer = new RecordsViewer();
XmlNode xml = record.ToXml(new System.Xml.XmlDocument()); //viewer.GetSingleXmlRecord(record, new System.Xml.XmlDocument());
XPathNavigator navigator = xml.CreateNavigator();
XPathExpression selectExpression = navigator.Compile("//fields/child::*");
selectExpression.AddSort("@pageindex", XmlSortOrder.Ascending, XmlCaseOrder.None, "", XmlDataType.Number);
selectExpression.AddSort("@fieldsetindex", XmlSortOrder.Ascending, XmlCaseOrder.None, "", XmlDataType.Number);
selectExpression.AddSort("@sortorder", XmlSortOrder.Ascending, XmlCaseOrder.None, "", XmlDataType.Number);
XPathNodeIterator nodeIterator = navigator.Select(selectExpression);
string list = "<dl>";
while (nodeIterator.MoveNext())
list += "<dt><strong>" +
Umbraco.Forms.Data.DictionaryHelper.GetText(
nodeIterator.Current.SelectSingleNode("caption").Value) + ": </strong><dt><dd>";
XPathNodeIterator values = nodeIterator.Current.Select(".//value");
while (values.MoveNext())
var val = values.Current.Value.Trim();
list +=
Umbraco.Forms.Data.DictionaryHelper.GetText(val)
.Replace("\n", "<br/>") + "<br/>";
if (this.Attachment == true.ToString() &&
val.Contains("/forms/upload"))
// add attachment
string filelocation = HttpContext.Current.Server.MapPath(val);
m.Attachments.Add(new Attachment(filelocation));
list += "</dd>";
list += "</dl>";
m.Body = "<p>" + Message.Replace("\n", "<br/>") + "</p>";// + list;
System.Net.Mail.SmtpClient s = new System.Net.Mail.SmtpClient();
s.Send(m);
return WorkflowExecutionStatus.Completed;
Default work flow email template.
Is it possible to edit the default email template used to send messages in workflow? Where would I find it?
Dan
Hi Dan,
/Dennis
Umbraco forms I've done this in Contour so guidance and a sample file would be great. Thanks
Hi Dan,
You can find the example file here \App_Plugins\UmbracoForms\Xslt\sendXsltEmailSample.xslt.
Take a copy of this file, and uploaded in the media library, then you can attach it on the workflow for your form.
https://our.umbraco.org/documentation/Add-ons/UmbracoForms/Editor/Attaching-Workflows/
Hope this helps,
/Dennis
Hi Dennis
Dan
Hi Dan,
If this not work for you then you can submit a feature request here. http://issues.umbraco.org/issues/CON
/Dennis
Hi Dan,
Here is a link that might help - it's a gist of the Send Email Workflow.
https://gist.github.com/TimGeyssens/3fffc0a4a6e457a0cd08
Also, workflows are coded the same Contour and Umbraco Forms - so any code for one should work for the other.
You should be able to modify the code above to create a new workflow to do what you need.
Dennis - I have added this as a feature request.
Joshua - that's what I needed though this is the latest version for Umbraco Forms here - https://gist.github.com/TimGeyssens/6ff5392c4d9bbf89bdfc
