I have upgraded our CMS to the latest version. Now when I set up a URL for our Form to redirect to (under the Actions dropdown) I get an error and the logged error is:
2016-02-10 16:05:41,504 [P5796/D5/T70] ERROR Umbraco.Forms.Data.LogHelper - Forms: workflow 'Post form to url' failed on Approved
System.Net.WebException: Could not find a part of the path 'c:\contact-us\thank-you'. ---> System.IO.DirectoryNotFoundException: Could not find a part of the path 'c:\contact-us\thank-you'.
at System.IO._Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITYATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at System.Net.FileWebStream..ctor(FileWebRequest request, String path, FileMode mode, FileAccess access, FileShare sharing)
at System.Net.FileWebRequest.GetRequestStreamCallback(Object state)
--- End of inner exception stack trace ---
at System.Net.WebClient.UploadValues(Uri address, String method, NameValueCollection data)
at Umbraco.Forms.Core.Providers.WorkflowTypes.PostToUrl.Execute(Record record, RecordEventArgs e)
at Umbraco.Forms.Core.Services.WorkflowService.ExecuteWorkflows(List`1 workflows, RecordEventArgs e)
Forms not submitting to url
Hi, I have upgraded our CMS to the latest version. Now when I set up a URL for our Form to redirect to (under the Actions dropdown) I get an error and the logged error is:
Can you pint me in the right location? Jon
