I have a question. I use ‘Forms’ 4.1.3, Umbraco version: 7.2.5.
I get double entries when submitting a form in my website when I:
use Internet Explorer (all versions)
use on submit ‘Go to Page on submit’
How can I fix this problem?
When I use on submit ‘Message on submit’, then I get 1 entrie after posting the form. So that seems to work properly.
But I want to use ‘Go to Page on submit’ so I can see in Google Analytics how many times the Thankyou-page has been visited.
I've had a similar problem since updating forms with the security patch - though i was having 3 submissions, i was able to cut that down to 2 now by adding the following to MacroPartials/InsertUmbracoForm.cshtml:
Html.RenderAction("Render", "UmbracoForms", new {formId = g, mode = "form"});
Adding the mode = "form" to the RenderAction.
If you already have this / it doesnt work then i believe we have the same problem, if you do find an answer i'd be glad to know.
I'm also having a problem with double submissions - this is affecting IE (just v11 tested), and not Chrome or Firefox.
I don't redirect to a new URL or node after submission.
Double entries
I have a question. I use ‘Forms’ 4.1.3, Umbraco version: 7.2.5. I get double entries when submitting a form in my website when I:
When I use on submit ‘Message on submit’, then I get 1 entrie after posting the form. So that seems to work properly. But I want to use ‘Go to Page on submit’ so I can see in Google Analytics how many times the Thankyou-page has been visited.
Hi Bas,
Thanks, Owen
Hi Owen,
When I try this the default stylesheet turns off. So I didn't test it further.
If I find solution i will post it here.
Bas
Is there a fix available yet?
(I'm on Umbraco Contour version 3.0.25)
