  • Tom Maton 387 posts 660 karma points
    Mar 02, 2010 @ 10:38
    Tom Maton
    Create a form with RadioButtonList & DropdownList errors
    Hi All,
    I'm creating a form via the route of Data Source.
    I get is once I have connected to my data source I click "create form" and chosen my fields to use from the table then click "continue" and I select a RadioButtonList click save form I get the following error:
    Umbraco.Forms.UI.Usercontrols.EditForm.GetPrevalueAttributes(Field f) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.UI\Usercontrols\EditForm.ascx.cs:179
    ASP.usercontrols_umbracocontour_editform_ascx.__DataBind__control9(Object sender, EventArgs e) +1707
    System.Web.UI.Control.OnDataBinding(EventArgs e) +73
    System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +139
    System.Web.UI.Control.DataBind() +15
    System.Web.UI.Control.DataBindChildren() +205
    System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +149
    System.Web.UI.WebControls.Repeater.CreateItem(Int32 itemIndex, ListItemType itemType, Boolean dataBind, Object dataItem) +124
    System.Web.UI.WebControls.Repeater.CreateControlHierarchy(Boolean useDataSource) +435
    System.Web.UI.WebControls.Repeater.OnDataBinding(EventArgs e) +53
    System.Web.UI.WebControls.Repeater.DataBind() +65
    Umbraco.Forms.UI.Usercontrols.EditForm.RenderFieldset(Object sender, RepeaterItemEventArgs e) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.UI\Usercontrols\EditForm.ascx.cs:114
    System.Web.UI.WebControls.Repeater.OnItemDataBound(RepeaterItemEventArgs e) +78
    System.Web.UI.WebControls.Repeater.CreateItem(Int32 itemIndex, ListItemType itemType, Boolean dataBind, Object dataItem) +136
    Umbraco.Forms.UI.Usercontrols.EditForm.RenderPage(Object sender, RepeaterItemEventArgs e) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.UI\Usercontrols\EditForm.ascx.cs:102
    Umbraco.Forms.UI.Usercontrols.EditForm.Page_Load(Object sender, EventArgs e) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.UI\Usercontrols\EditForm.ascx.cs:59
    System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
    System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +43
    System.Web.UI.Control.OnLoad(EventArgs e) +73
    System.Web.UI.Control.LoadRecursive() +52
    System.Web.UI.Control.LoadRecursive() +141
    System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2156
    Any help would be much appreciated.
    Tom
  • Comment author was deleted
    Mar 03, 2010 @ 16:56
    Hi Tom,
    Is this when using a prevalue source or when creating a form based on a datasource?
    Mar 03, 2010 @ 16:59
    Owkey I see from the trace that it occurs when using a prevalue source, are the settings on the prevalue source ok? (it should check the settings when saving the prevalue source)
    Mar 05, 2010 @ 10:50
    Tom Maton
    Hi Tim,
    The values are fine and the values I manually entered them as they are just numbers 1 to 5 and not pulling from a database or anything like that.
    Tom
    Mar 06, 2010 @ 16:48
    Thanks for the additional info Tom, will take a look at the issue on monday and hopefully include it in the next maintenance release
    Mar 06, 2010 @ 16:52
    Can't reproduce the error, would it be possible to outline the steps to reproduce the error? And also what db engine are you running on?
    Tim
    Mar 08, 2010 @ 16:08
    Tom Maton
    Hi Tim,
    I can't seem to replicate anymore myself. Hmmm, thats annoying....
    If it happens again I will let you know.
    Tom
    Mar 08, 2010 @ 16:30
    Owkey thanks for the update Tom
  • Joey Kincer 51 posts 83 karma points
    Mar 17, 2010 @ 08:00
    Joey Kincer
    Hi there,
    I'm getting this same problem too when I try and create dropdown lists from 2 of my field properties and save the form (making all text fields goes through OK). I'm using the Dataset method from SQL Server to generate my properties.
    I do admit I'm new to the Contour thing, so maybe I'm doing something wrong. I've created a few Prevalue Sources (State and Country for the dropdowns) but I don't see how to connect those and the DataSource together. Where are the Prevalue source settings and how do I get them to talk to each other?
    Line 223:     <div class="fieldprevalues" style="display: none;" <%# GetPrevalueAttributes(((Umbraco.Forms.Core.Field)Container.DataItem)) %>>
       ASP.usercontrols_umbracocontour_editform_ascx.__DataBind__control9(Object sender, EventArgs e) in c:\inetpub\umbraco\usercontrols\umbracoContour\EditForm.ascx:223
       System.Web.UI.Control.OnDataBinding(EventArgs e) +99
       System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +92
       System.Web.UI.Control.DataBindChildren() +211
       System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +102
       System.Web.UI.WebControls.Repeater.CreateControlHierarchy(Boolean useDataSource) +443
       System.Web.UI.WebControls.Repeater.OnDataBinding(EventArgs e) +51
       System.Web.UI.WebControls.Repeater.DataBind() +75
       System.Web.UI.WebControls.Repeater.OnItemDataBound(RepeaterItemEventArgs e) +108
       System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
       System.Web.UI.Control.OnLoad(EventArgs e) +99
       System.Web.UI.Control.LoadRecursive() +50
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
  • Selah 7 posts 27 karma points
    Apr 14, 2010 @ 00:50
    Selah
    I'm having the same issue. I'm creating a table from a SqlServer table datasource. Textfields work just fine, but if I select a checkbox list, for instance, I get the same error as above.
    Apr 14, 2010 @ 09:17
    Hi Selah, would it be possible to provide the different steps you do ? That way I can try to reproduce the error and get it fixed!
    Apr 14, 2010 @ 18:54
    Selah
    Sure thing.
    1. Create a SQL Database Data Source in Contour
    2. Create a form for that data source
    3. Check some fields and continue
    4. For one of the fields, select either the "CheckBoxList" or "DropDownList" fieldtype
    5. Save form
    6. Boom!
    Here's the output:
    Source Error:
    Line 221: update</a> <a class="iconButton delete" href="#" onclick="javascript:DeleteField('<%# ((Umbraco.Forms.Core.Field)Container.DataItem).Id %>');">
    Line 222: delete</a> <span class="handle">handle</span>
    Line 224: <asp:Repeater ID="rptPrevalues" runat="server">
    Line 225: <ItemTemplate>
    Source File: c:\inetpub\ubb-survey\usercontrols\umbracoContour\EditForm.ascx Line: 223
    Stack Trace:
    ASP.usercontrols_umbracocontour_editform_ascx.__DataBind__control9(Object sender, EventArgs e) in c:\inetpub\ubb-survey\usercontrols\umbracoContour\EditForm.ascx:223
    Version Information: Microsoft .NET Framework Version:2.0.50727.4200; ASP.NET Version:2.0.50727.4016
    Apr 15, 2010 @ 09:55
    Thanks Selah,
    And what if you only make 1 field checkboxlist or dropdown, does it save succesfully in that case?
    Apr 15, 2010 @ 17:17
    Selah
    It also breaks with 1 checkboxlist or dropdown. Are you unable to reproduce the bug?
    Apr 15, 2010 @ 17:23
    Hi Selah,
    Thanks for the info, no I'm not able to reproduce the error.
    Would it be possible to provide a screenshot or some info on the table you are setting up in the datasource?
    Apr 15, 2010 @ 22:24
    Selah
    I'm using SQL Server 2005 / IIS 6.0 / Windows Vista SP2
    Table schema doesn't seem to make a difference. I've tried on a few different tables on columns with varying data types.
    I just duplicated the bug against this test schema:
    CREATE TABLE [dbo].[Test](
    [One] [varchar](50) NULL
    ) ON [PRIMARY]
    The Fieldtypes that cause the error are the CheckBoxList, DropDownList, and RadioButtonList. I believe these are the field types that accept prevalues, which may have something to do with the issue.
    I am not using any prevalue sources.
    Here are links to screenshots of the problem:
    1. db setup
    2. form setup 1
    3. form setup 2
    4. boom
    And here's a link to RenderForm.aspx, which I have not altered.
    If there's any other way I can help, let me know.
    Apr 17, 2010 @ 10:49
    Thanks for the detailed info!
    Currently when selecting a checkboxlist, dropdownlist, radiobutton list when creating a form based on a datasource these fields should be linked to a lookup table.
    So it's currently not possible to populate the dropdown from within the form designer.
    Will log this issue and it will be taken care of in the next release!
    Apr 19, 2010 @ 18:58
    Selah
    "Currently when selecting a checkboxlist, dropdownlist, radiobutton list when creating a form based on a datasource these fields should be linked to a lookup table."
    Is it possible to set this up when using a datasource? Otherwise, is there another workaround you can think of?
    I'm using Contour for a project with a rapidly approaching deadline, and the inability to use dropdownlists will be detrimental.
