  • Kaj 41 posts 73 karma points
    Mar 08, 2010 @ 09:30
    Kaj
    The issue about dropdown?
    Is ther any update patch who had solve the problem to get the content from dropdown-list out on a webform??
    Best regards,
    Kaj
  • Comment author was deleted
    Mar 08, 2010 @ 09:49
    Hi Kaj,
    Is it this issue: http://our.umbraco.org/forum/umbraco-pro/contour/6773-Including-Dropdown-Lists-in-Workflow-Emails ?
    Or something else related to the dropdown list ?
    Tim
    Mar 08, 2010 @ 10:00
    Kaj
    Hi Tim
    Yes is about: "Am i wrong, has anyone used the default dropdownlist feildtype, added values and successfully tried using this to populate a node textstring?"  ???
    I really need for a customer.
    Kaj
    Mar 08, 2010 @ 10:49
    Looking into the issue now, should be part of the new maintenance release (that will be out this week).
    Mar 08, 2010 @ 11:22
    Kaj
    Thanx Tim!
    Mar 08, 2010 @ 11:52
    Kaj
    Tim I have one more quistens.
    I try to mail you about moving my contour from a temp url to ordinarie url, but I down´t get any answere?
    Can you help me with that??
    Thanx,
    Kaj
    Mar 08, 2010 @ 12:22
    Sure Kaj, will look into it and send you the updated license.
    Regards,
    Tim
    Mar 08, 2010 @ 12:39
    Kaj
    Oh, thanx Tim! :-)
    Best regards,
    Kaj
    Mar 08, 2010 @ 13:51
    Hi Kaj
    Just mailed you the updated license.
    Tim
