Currently (version 1.0.8) the send as email workflow doesn't give you any control of the contents of the mail.
But in the next maintenance release we'll add a new send as email workflow where you have control over the contents of the mail (by using some xslt to transform the record).
Some questions about Contour
* Is it possible to brand the outgoing emails that we send using email workflow task ?
* Is it possible to have the users IP adress included in the email
* can we somehow have specific (sales / support / ..) email adresses for different forms ?
Kind regards,
Rik
Comment author was deleted
Hi Rik,
Per posted the complete sourcecode for that workflow on the forum here: http://our.umbraco.org/forum/umbraco-pro/contour/6201-Sending-custom-emails-with-contour---howto
You can use that to create a custom workflow where it's also possible to set the email addresses.
And adding ip is also possible, check the developer docs: http://umbraco.org/pro-downloads/Contour%20Developer%20Docs.pdf (page 13)
