Any way to debug way entries cannot be found in backend?
The notification emails goes through.
Comment author was deleted
Hi Nikolas, could you give some details on the form? What field names are you using?
Hi Tim,
Fields are:
Navn (Textfield)Postadresse (Textfield)Postnummer (Textfield)Poststed (Textfield)Telefon (Textfield)E-post (Textfield)Kommentarer (Textarea)Kode (ReCaptcha)
I can access the submitted data from XSLT as I use the XsltEmail workflow to deliver data and it seems to work fine.
So basically it seems like its only via backend that it's not working as intended.
Upgrading from 1.06 to 1.07 solved the problem.
No entries in backend but notification emails work
Hi Tim,
Fields are:
Navn (Textfield)
Telefon (Textfield)
E-post (Textfield)
Kode (ReCaptcha)
