One of my clients is using IE6 and when they go to export the results all they see is the format types and once they select their format they dont get an export button displaying. Its on the page as I have viewed the source but its just not viewable.
Exporting results in IE6
Hi All,
Any got a fix for this?
I'm using the latest stable version of contour.
Tom
Hi Guys (Umbraco Developers mainly),
I've found the issue.
In the dialogs.css for UmbracoContour you need to change the following
div.propertyItem .propertyItemContent {
clear:right;
float:left;
padding-bottom:5px;
to
clear:right;
float:left;
padding-bottom:5px;
position:relative;
adding the position:relative to the css will display the button and text.
Tom
Comment author was deleted
Thanks Tom! I'll make sure this gets added to the next maintenance release
