  • Anders Holmér 20 posts 41 karma points
    Mar 24, 2010 @ 17:13
    Anders Holmér
    Bug when edit values in checkboxlist
    I  use Contour 1.0.7 (lic), (umbraco 4.0.3), and when I changed a item value in checkboxlist and press update, the text disappears completely, and you can not save a new value. The only way is to delete and recreate, but then I lost all old data.
    Regard
    Anders
  • Comment author was deleted
    Mar 31, 2010 @ 20:01
    Hi Anders,
    I would recommend to upgrade to the latest stable version of Contour wich is v1.0.9, you can find the upgrade files here: http://nightly.umbraco.org/Umbraco%20Contour/
    Apr 07, 2010 @ 17:12
    Anders Holmér
    Thanks Tim, it works fine now
