  • Bruce 3 posts 23 karma points
    Mar 29, 2010 @ 15:34
    Bruce
    Multiple step form problem
    I am having a problem with Contour v1.0.9 when I use a form created with multiple steps, the data is only being recorded from the last step. Single step forms have all the data recorded.
    Has anyone else experienced this?
    Bruce
  • Comment author was deleted
    Mar 31, 2010 @ 11:51
    Hi Bruce,
    Just tested it and multiple steps forms work fine, what did you use to install v1.0.9 did you try a build from our build server?
  • Josh Reid 182 posts 258 karma points
    Apr 03, 2010 @ 10:46
    Josh Reid
    Same issue here.
    Installed with 1.0.7 back in Jan and upgraded to 1.0.9 from nightly's - replaced bin, uc's and plugin as well.
    Tested existing as well as newly created multi step forms.
    All else seems to be working well.
    Apr 08, 2010 @ 11:06
    Hi Josh,
    Looks like this was caused by an issue on our build server.
    I've just released Contour v1.0.9.1 (which fixes the multiple step problem introduced in the 1.0.9 builld)
    You can get the package and hotfix (for updating) here:
    http://nightly.umbraco.org/Umbraco%20Contour/1.0.9.1/
