  • Erik Ernst 70 posts 90 karma points
    Mar 31, 2010 @ 19:29
    Erik Ernst
    Contour with external SQL source - mandatory fields
    I've created an external SQL database source pointing to a Dynamics NAV / Navision database.
    When I create a new form, then it lists all the fields in the able. The problem that occurs is that all of the fields in the table is automatically selected and I'm not able to deselect them.
    Rgds,
    Erik
  • Comment author was deleted
    Mar 31, 2010 @ 20:00
    Hi Erik,
    Contour will check what fields don't allow null values, and the ones that don't allow null values will be selected automatically (without an option to deselect since this will cause problems).
    Mar 31, 2010 @ 20:37
    Erik Ernst
    Hey Tim,
    You're right! Thank you.
    But I would like to know if there is a way so that I could pre-assign default values to certain fields and hereby not displaying them to the user.
    Mar 31, 2010 @ 20:43
    Hi Erik,
    Currently that's not possible, but it will be in a feature release.
    Mar 31, 2010 @ 21:29
    Erik Ernst
    Hi Tim,
    Ok, thank you, than I will already start to look forward to that version...
    Erik
