  • Laurence Gillian 600 posts 1219 karma points
    Apr 01, 2010 @ 13:35
    Laurence Gillian
    RenderMacroContent & Contour
    Has anyone tried using the RenderMacroContent extension with Contour?
    This is my code, which I would of expected to have worked;
    <xsl:variable name="Macro">&lt;umbraco:Macro FormGuid=&quot;b56a1ad1-284f-4feb-b8b3-a0beb5b74b6c&quot; Alias=&quot;umbracoContour.RenderForm&quot; runat=&quot;server&quot;&gt;&lt;/umbraco:Macro&gt;</xsl:variable>
    <xsl:value-of select="umbraco.library:RenderMacroContent($Macro, $currentPage/@id)" disable-output-escaping="yes"/>
    Also, is it possible to change the default 'submit' value from 'submit' to a custom value?
    /Lau
  • Comment author was deleted
    Apr 01, 2010 @ 13:39
    Hi Laurence,
    It's not supported to run a usercontrol macro (wich the Contour macro is) from inside xslt.
    Changing the value is possible by setting up a dictionary item called submit
    Apr 01, 2010 @ 13:46
    Laurence Gillian
    Thanks Tim, I guessed this was probally the case.
    Yep and the same on the 'Submit' front, we need different text on different forms. Going to have a look around the source that was posted online a few days ago, failing that I can just update the fields values using some jQuery targeting.
    Thanks for the super fast reply though! :) Lau
    Apr 01, 2010 @ 13:51
    Yup currently it's set globally, updating with some JQuery is a possible workaround
    Tim
